Importing no PIX4D orthomosaics
Hi!
When I import a multiespectral raster image using the “other maps” menu some bands are missing. I can only see Red, Green, Gray, Gray and alpha. In QGIS the bands appear correctly: Grenn, Red and NIR. How can I solve this? I understand that PIX4D works better when reads PIX4D orthomosaics but I woul like to use some features of the software with orthomosaics from other sources.
Hi, it seems the TIFF file has corrupted band labels. Could you share the ortho with us?
Hi Jose!
I can’t share the orthomosaic since is from a research trial. A private dron operator generated the orthomosaic. In QGIS all bands appear perfectly, I have tried to open the raster in QGIS and export it again but it doesn’t work, PIX4D doesn’t read the labels properly. What can i do If the band labeles are corrupted?
Thanks!
Are you trying to import a composite image with these bands? Or just each reflectance map individually?
You might want to try a program like GDAL. I believe this program would allow you to overwrite and/or rename the bands.
