Importing external point cloud to PIX4D Matic
Good evening, is it possible to import an external point cloud to PIX4Dmatic in order to generate a DSM?
Hi @jm.valladares21 ,
Welcome to our community!
You can refer to this article to see all the input options when using PIX4Dmatic. Right now, it is not possible to import an external point cloud and generate a DSM in PIX4Dmatic.
Inputs - PIX4Dmatic
Rosana (she/her)
Hi @jm.valladares21
Rosana is right in that we don’t support this right now. That said, we’re working towards making this work in the future.
Do you have an example when you would need this ? This will help understand the context of your request and give arguments to making this happen sooner.
Thank you.
Pierangelo
Hi, @Pierangelo_Rothenbuhler
I have a photogrammetry project and used Pix4D Matic to generate the point cloud. As I needed a DTM, I used Pix4D Survey to classify the point cloud as terrain and not terrain and it worked fine. Now, I know I can make TIN surfaces and contours in Pix4D Survey but I need the DTM (or in this case the DSM of the terrain classification) but as far as I know it is not possible in Survey.
Hi jm.valladares21,
If you are looking for a DTM, can export the TIN as a DTM. This will give you a terrain layer that is a raster surface.
In a similar vein, we would like to be able to export an OBJ of the terrain only TIN from Survey but it is not an option. The LandXML file is often is too large to convert in third party software so this option would be very useful.
Alternatively, Matic does allow OBJ export but there is no way of generating or importing terrain only points in it.
Any chance one of these options will become available??
@jm.valladares21 Hi, in case you have not seen it yet, you can import a point cloud into PIX4Dmatic for mesh, DSM, and orthomosaic generation, as well as vectorizing, classification, and the for the terrain workflow (grid of points, TIN, contour lines): check out this video and this article. You can also directly generate a DTM with PIX4Dmatic. I hope this helps!
@nat.marsden which third-party software do you need to import a surface into? And what would you like to achieve? So that we can check compatibility.
