Importing CAD solids (.dxf vector layer)
Adding solids as a possible .dxf vector layer.
e.g. allowing you to import 3D Utility CAD drawings, solid layer showing chambers depths and sizes
Hello @matt.wicks,
Welcome to the community, and thank you for the feature request. I would also recommend you to click on the vote so that the product manager can see how many people are requesting this feature.
Jon
Hi @matt.wicks, that’s a good idea, thank you! Today the best option would be to explode those 3D objects down to polylines/polygons, then import. We’ll still respect the 3D element, though the rendering can be a bit different.
Here’s an example of some 3D buildings imported into Survey after exploding - a bit blocky, and the mesh triangles are individually rendered, but you also get the idea:
Nate
