Importing Boundary
Good Morning All
Do you know if we will be able to import a processing boundary soon to pix4dmatic? This was a useful feature in mapper which doesnt seem to be in matic but it helps to produce consistent results.
Mat
Hi Mat,
The feature you are describing seems to be already implemented as “region of interest (roi)”:
Daniele
hI @operations2
it’s not described yet in the documentation link that @Daniele_Lecci has shared, but it’s possible to import the ROI as .kml file, which will serve as your processing boundary. You can adjust the height (top and bottom) in the 3D view.
File > Import > Region of interest… then select your kml file.
