Is there a way to import a DXF file into existing raycloud?
That would be great, especially a 3D dxf drawing.
Hi Jaco and Balint,
Unfortunately, it is not possible to import a dwg or dxf file into the rayCloud. You can only import a point cloud (.las file) that corresponds to the images of the area in order to use it as an input for step 3.
For more information about how to do this you can take a look here: https://support.pix4d.com/hc/en-us/articles/202560049.
In general please keep in mind that the only inputs to the software are the images and the GCP coordinates’ files.
