Import Pix4d 3D model in Autocad
French !
Bonjour,
je suis télépilote en photogrammétrie, j’aurais quelques question pour développer notre système d’installation de panneaux photovoltaïques.
Actuellement, les plans des toits étaient fait manuellement, ce qui engendrait des erreurs et une perte de temps concrète.
Nous avons essayé le logiciel Pix4Dcapture, et il convient parfaitement à nos attentes.
Ma question est simple, suite à la prise du logiciel, est-il possible d’exporter dans différents formats de fichiers ?
Actuellement, Autocad accepte les fichiers DWG et DXF
Merci d’avance
English!
I am a photogrammetry drone pilot, I would have a few questions to develop our system for installing photovoltaic panels.
Currently, roof plans were done manually, which led to errors and a concrete loss of time.
We tried the Pix4Dcapture software, and it perfectly suited our expectations.
My question is simple, after taking the software, is it possible to export in different files formats?
Currently, Autocad accepts DWG and DXF files
Thanks in advance
Hello nicolas,
PIX4Dmapper can export many files in DXF. This includes contours, 3D mesh, and any vectorized features such as points, lines, or polygons you create in the rayCloud. PIX4Dsurvey will also export the TIN as a LandXML file which can also be imported into AutoCAD.
Nicolas,
What output do you want to bring into CAD(ortho, pointcloud, etc)? Are you just using autocad, or are you using Civil3D?
