Import contours-shapefile
It would be nice if there was an add dataset option for vector files such as contours (shp and dwg format) to overlay on top of the point cloud. As well as being able to turn off and on classes in the point cloud.
you can try using import in the annotions layer.
importing .SHP is possible here, note that only WGS84 is supported.
I would love to see ESPG code support in the future!
You can import the contout lines in DXF format.
Please see: Visualize your DXF overlays in 3D
Daniel.
