Hi, dear community members ![]()
I hope you can help a newcomer.
I am writing to seek assistance regarding an issue I am encountering with the alignment of images in Pix4Dmatic. Our photogrammetry project involves the use of a viDoc RTK rover and an RTK drone (Mavic 3 Enterprise RTK), and we recently captured a site using these devices.
The workflow includes the use of ground control points (GCPs) for accurate georeferencing. The coordinates of the GCPs were obtained using the viDoc rover and are in the NAD83 (2011) coordinate system (EPSG: 6318) for horizontal positioning, with vertical positioning based on ellipsoidal height and no geoid transformation applied.
However, when I upload the images captured with the viDoc rover into Pix4Dmatic, they are positioned incorrectly compared to the GCPs and the images from the drone. The coordinates in the metadata of the misaligned images show significantly different values compared to the correctly positioned images.
For example, the latitude and longitude values of one of the misaligned images are 9.910808333333334e-05 (latitude) and -2.817591666666667e-05 (longitude), whereas those of one of the properly positioned images are 40.739088583333334 (latitude), -73.84138852777777 (longitude).
Unfortunately, I do not have information on the coordinate reference system (CRS) of the misaligned images, which complicates the troubleshooting process.
I would greatly appreciate any guidance or assistance you can provide to resolve this issue. Specifically, I am seeking insights on how to ensure proper alignment of images captured with the viDoc rover in Pix4Dmatic, considering the known CRS of the GCPs.
Any input is highly appreciated.
Alek Alergant
