i/O issue when creating Mesh from P.Cloud
Any quick fix for this error which keeps coming when creating the Mesh:
[2024-11-17 09:53:37][01%CPU][65%RAM]Generate computed depth maps An I/O issue for the temporary data: ProjectedPointWriter::dump() I/O failure writing file C:\Users\User\OneDrive\Documents\Pix4Dmatic\NC-1 3D Mapping\processing\depthmaps\pix4d-depthcompletion-1da6-d0a7\pcl-buffer.dat with message: ios_base::badbit set: iostream stream error
[2024-11-17 09:53:37][01%CPU][65%RAM][Generate computed depth maps] Error
[2024-11-17 09:53:37][01%CPU][65%RAM]Generate computed depth maps Generation of depth maps failed
Processing time 23m 19s
My SSD Hard Drive (C) has 224 GB free. WHat might be the issue?
Could you share the log file, please?
I am not sure that it is the source of the error, but from the path "C:\Users\User\OneDrive" it looks like the Documents folder is managed by OneDrive. Could you try copying your project to a different folder, e.g., to “C:\NC-1 3D Mapping” and to try processing from there?
Kind regards,
Alexey
The issue was with hard drive “C” reaching 85% full, when freeing more space the problem gone!
