Hi team,
I have been running with this issue when creating a point cloud, I have a project of about 2400 photos, and I have been changing the image scale, algorithm and nothing seems to be working, at first the issue was the storage availability, which I freed up a lot of space in my drive, but doesn’t seems to be working.
If somebody can point me in the right direction, that it’ll be much appreciated!.
Thank you
here is the log file
2025-01-13_14-06-57.txt (2.6 MB)
[2025-01-13 14:54:26][17%CPU][44%RAM]Generate dense point cloud data Failed to read or write a resource on disk
IO-error on file “C:\Users\felipe.godoy\OneDrive - Thomas Consultants Limited\Desktop\Cedel Downs - Red Hills-Amreins Rd\Matic\Ced 1\Project_2025-01-13_14-04 - Cedel 1\processing\densifications\private\900d61f3-6851-4284-b09b-8373729006e3\pix4d-densify-4d75-1db3\globalSeeds.dat”
I wonder if this has something to do with using OneDrive. I had previously considered using that myself, but was worried about what might happen if OneDrive tried to sync while it was in the middle of processing, so now I use an external SSD and move completed projects to OneDrive for backup storage.
Indeed that was the issue, I normally save my projects in my local drive, separate folder, but for some reason it wasn’t allowing me to read or write anything in there, so I end up using the default path Pix4D creates when starting a project which is in a different location I think, and had no issues whatsoever.
