How to View Metadata?
Where do you find data for
Altitude
GPS Coordinates
Camera Angle
Distance an object (if any) is from the collision sensor (P4) - this one would be REALLY helpful for my application
Can any photo EXIF viewer display it?
Hi Jeff,
Normally, the drone registers information about the position and orientation of the images in the EXIF or in a txt file:
txt images file
Pix4D, by default will optimize these values. We export the optimized values in the Output Params Folder.
Could you give us more information about the “Distance an object (if any) is from the collision sensor (P4)”? Do you refer to the focal length? Do you refer to the distance an object of your area has from the sensor?
Looking forward to receiving news from you,
Christina
