HOW TO LABEL MY CONTOUR LINES IN PIX4D MAPPER
WHEN I EXPORT MY CONTOUR IT DOES NOT COME WITH LABELS
Hi Fred,
If you export your contour lines as shapefile and open it with a GIS software such as QGIS, you will be able to label your contour lines in the layer properties tab “Label” and then you have to select the right column of the attribute table here “Elevations”.
