I would like to change the line weight of the contours generated in step 3. Does anyone know if that’s possible?
Hi @eparker,
Welcome to the Pix4D Community
If you export contour lines in .shp or .dxf format, you will get polylines. You can modify the wight/size of the lines within the 3rd party software you are using to display/manage/edit the contour lines:
.shp
- Global Mapper
- ArcGIS
- Quantum GIS
.dxf
- AutoCAD
- Global Mapper
- ArcGIS
- Quantum GIS
Thanks for the great answer, Daniele. Because of time constraints, I’m having to learn as I go for now. I’m getting familiar with Global Mapper.
Eric Parker
Research Support Services, Inc.
206.550.5202
www.rssincorporated.com
