Help! Aborting for second battery map shifts!
When I click Abort then Go Home to swap battery my map moves and I can see the original location and the shifted location but can realign it.  I’m careful to only press my finger on the Go Home button.  So then I have to duplicate the mission and remap the remaining portion! Anyone experience this? (Android tablet)
Depending on the type of mission you are planning, the behavior you are describing is expected.
You can find the procedure to operate multi-battery missions on the Android version of Pix4Dcapture here.
In case you are not planning a Grid mission, if you tap ABORT+GO HOME, a new mission will be automatically created besides the first one. As it has been reported as a pain point by some users, we may consider changing the way it is done in the future.
