Hardware Question
New user here trying to pick a laptop for field use of Pix4d fields. Intend on mapping Avocados with a Mavic 3 Multispectral, jobs up to 150ha flown at 60m with standard overlap.
I was considering the following, but it doesn’t have an HDD, is this likely to be an issue? Or any other issues you might see as limiting with this selection.
I was considering the following, but it doesn’t have an HDD, is this likely to be an issue? https://www.pbtech.co.nz/product/NBKHNB161137BSS/HP-Victus-16-d1137TX-RTX-3060-Gaming-Laptop-161-FH)
Any help would be much appreciated!
Hi Micheal,
PIX4Dfields works best with an SSD, so that choice of yours should serve you well. You will need an external HDD to store your datasets at some point though.
