Generating the orthoplane
I am on version 4.4.12 using Pix4DModel.
I am trying to use the orthoplane to improve the mesh quality.
I have tried numerous times on different models but am getting the same results. I make the Orthoplane, align to a surface, and click “Apply.”
From that point the pix4D stops. It is not freezing or crashing but it does not progress. The “Generate” button is grayed out and unavailable. I have attached a picture below to show you what I am seeing.
Is there something I am doing wrong? I am following the tutorials as exact as possible.
Hi Brad,
As you are using Pix4Dmodel, you cannot export the Orthoplan. That’s why this option is grayed out.
However I think that you want to use the surface tool instead of the orthoplan tool.
These articles should help:
How-to-draw-a-Surface-in-the-rayCloud
How-to-improve-the-3D-Textured-Mesh
Best
