I have generated an orthoplan on a facade, but the rendering is noisy by all that is around this facade. Is it possible to clean the orthoplans or the points cloud under pix4D before generating the orthoplan? The idea would be to have a better visual rendering.
Also I filtered my cloud of points generated on Pix4D on another software and I imported it with the command " import a point cloud for the generation of an MNS". However, the cloud does not appear in the 3D space nor in the tree which is a pity. Moreover, it is impossible to generate an orthoplan with this new cloud but only a orthophoto “blindy”.
Yes, there are a few ways to clean the point cloud and to improve the orthoplane:
Manual Tie Points (MTPs)
For such projects, we noticed that adding MTPs can help a lot to remove noise from the reconstruction, e.g. to create only one layer of points. More about that here:
This feature is mostly meant to import point clouds to create Digital Surface Models (DSM) from projects with images taken from nadir, e.g. with a grid flight from a drone.
We would rather suggest to use the tools described in points 1 to 3.
Hope it helps!
If someone has other tips, please share them
I used a dual processor Xeon with 256GB RAM and for 3000 pictures were necessary 31 days
in the same time, the AgiSoft Photoscan led me to an acceptable results
