when I attempt the geo link step for my GCPs, they all float above the pix surface and no imagery will depict in the right side pane when I click on one the GCPs in the rayview pane. Both the gcps and the pix output are the same projection, feet. How can a I adjust the GCPs to get the flight pics to depict?
Hi klucas,
When the GCPs are hovering above the cameras, you cannot use the rayCloud to mark the GCPs. This is because Mapper believes the GCPs are outside the camera’s field of view. The solution is to use the Basic GCP editor, not the rayCloud.
If you mark three GCPs in at least two images each, then reoptimize, it will adjust the camera positions. Then you can use the rayCloud to continue marking your GCPs.
