Files not generated during 1. Initial Processing for merged project
I am wondering why these files are not being generated during 1. Initial Processing and how to correct this.
_measured_estimated_gcps_position.txt
_wkt.prj
_tp_pix4d.txt
_pix4d_calibrated_internal_camera_parameters.cam
_calibrated_camera_parameters.txt
Hello Nicolas,
Check that the option > Export > Camera Internals and Externals, AAT, BBA is selected in the Processing options window, as you can see below:
Let me know if it is the case for you or not.
