Fenceline/Corridor Spraying Operation
One of my target markets is spraying fencelines on larger ranches. I have tried multiple options in P4DF to create a spray op to target just the fenceline. I have had some success, but is rather tedious, and in some cases I have not been able to accomplish my goal. I know there are other apps available which allow the creation of corridors. Am I missing something? If not, is this option something on the Pix4Dfield radar?
As an example, in this photo, I would like to be able to create an operation to spray only along the red line annotation.
Mavic3M/AgrasT40
you can create a small corrdior field boundary around the fenceline, by drawing th eouter boundary first and then add a hole in the middle of the field.
I appreciate that idea Julius, and have tried a similar approach. The issue is that the area is not symmetrical, and what would happen using your example is that when uploaded, the area in the bottom left would not be wide enough for a spray pass, and the area in the upper right would create multiple passes. This, of course, could be fixed by additional adjusting of the boundary points, but that’s the tedious part I was trying to get away from.
Maybe the ability to create a field “x” feet either side of a centerline could be a future feature.
I have an idea on how to solve it, I send you a PM.
