Non-grid spot spraying missions
Hi all,
I am looking to use Pix4D fields to plan out spot spraying of invasive brush species. Is there a way to plan the targeted operations mission without having the drone fly a grid? Rather, treat every area that needs to be sprayed as a waypoint essentially? This would save me a ton of time.
Thanks!
Hi Ethan ,
that may depend on your brand. DJI can’t do it as far as I know ,maybe that changed with latest updates which came with the T50. There your only option is to modify the spray boundary so that it tightly encloses the application areas.
With Xag vehicles I know they are rolling out an update which will allow to automatically delineate the most efficient path for spot spraying missions .
