When generating grid patterns, it would be helpful to be able to double click on an obvious sprayer track and have the rotation angle snap to the track angle. Alternatively, let me import my AB lines from the spray console or worse case, let me mark an AB line in Fields that the grid can then snap to.
I know my sprayer geometry and dimensions but the angle varies across seasons. From a variable rate prescription perspective, I can only change rate across the full width of the sprayer. Having the grid misaligned with the spray angle gives unpredictable results.
Pete
