Faster way to upload photos?
Newbie here… I just flew 12 missions to capture 2,000+ acres for an initial photomosaic in Pix4DFields. I need up process all of these, but the workflow requires me to select a folder, and wait for it to scan the images, and then add each of the following folders one by one. It takes a loong while.
I could copy all of the folders into one folder and select it and walk away for awhile and come back once to start the processing. But this “scanning images” seems long a wasted step.
Any suggestions about how to improve this workflow?
-Mike
You can select also the parent folder and it will scan all the images.
If you want to speed up the process you need to make sure that you copy all the files on your local SSD first! Dont proess from an SDCard please.
Excellent guidance! Many thanks!!
