Is it possible to export the point cloud in a different .las format version (i.e. las 1.2)?
Hi @jpilartescongo,
You cannot export the point cloud in a different .las format version but you can convert the pointcloud to any version you want by using/downloading Lastools and run the command below:
path_to_the_lastools\LAStools\bin\las2las.exe -i path_to_the_point_cloud\pointcloud_name.las -epsg 3763 -set_version 1.2 -o path_where_pointcloud_should_be_saved\new_pointcloud_name12.las
las2las.exeis the program you wish to run -
pointcloud_name.lasis the file you act upon -
-set_version 1.2is the command option for changing the version -
-o new_pointcloud_name12.lasindicates that you wish to create a new output file with the name mentioned
Let me know if this does not work.
