Hello to all,
Whenever exporting DTM in tiff format to Civil3D, it takes too long to convert it to surface! For large area it will be impossible; any solution to this problem please?
Hello to all,
Hi @akoeng79, the easiest way to get the DTM into CAD software is to use the Pix4Dsurvey.
It can classify point clouds into terrain and non-terrain classes and generate a representation of the ground surface by only using the terrain points. The workflow is the following:
The TIN can be exported as a surface in LandXML file format which is fully compatible with CAD software.
Thank you Blaz!
Does Pix4dSurvey produce ortho mosaic? We need both the ortho photo and the DTM.
