Export Automatic Tie-Points as MTP/GCP table?
Is there a way in Pix4d Mapper to export the Automatic Tie-Points into a table that could be used to import as MTP/GCPs?
Hi Richard,
Unfortunately there is not a way to export the automatic tie points to a table. If there was the table would be extremely large. So it is not practical. However you can export manual tie points.
