Hi
I’m reaching out with a technical issue that I’ve been facing lately and could really use some insights or solutions. It’s a bit of a niche problem involving the QLogic QML2692 16 Gb Enhanced Gen 5 Fibre Channel Adapter for Flex System and the stability of Pix4D during data uploads.
I recently upgraded to the QLogic QML2692 Ethernet Adapter on my system to enhance my data transfer capabilities. My work heavily relies on processing and uploading large datasets through Pix4D, a photogrammetry software. However, since the upgrade, I’ve been experiencing some inconsistencies during the data upload process.
- Upload Interruptions: During the data upload to Pix4D Cloud, I’m noticing sporadic interruptions. The uploads pause abruptly and then resume after a short while, affecting the overall efficiency of my workflow.
- Network Fluctuations: Even though my network connection seems stable, the Pix4D upload seems to be sensitive to any minor fluctuations, causing temporary upload failures.
- Speed Variation: The upload speed isn’t as consistent as it used to be. While it sometimes reaches high speeds, it often drops unexpectedly.
I’m turning to this community in the hopes that someone might have encountered a similar situation or has expertise in this area. If you’ve experienced something similar or have insights into how the QLogic QML2692 adapter might interact with Pix4D’s data upload process, your guidance would be greatly appreciated.
Thank You
