Error when using 'Arbitrary CRS'
Hello.
I get small object by PIX4Dcatch.
After scanning, I try to analyze by PIX4Dmatic (v1.35.0 : Stable version).
‘Arbitary CRS’ cannnot use.
Best Regards.
Seiichi Takayama
Hi seiichi_takayama,
Are you able to share the project? If it is still in your PIX4Dcloud account, please share the project link and I can access the files from the back end.
Was it able to process previously?
If no longer in the cloud, I can provide a shared link for upload.
-Jon
Hi Jon
This is ‘PIX4Dmatic’ problem.
I uploaded project files and PIX4Dcatch-files , below.
Please inform me if you finish downloading. (I will delete soon.)
Best Regards,
Seiichi Takayama
Hi Seiichi,
Thank you, the file is downloaded.
I see a project containing 74 images, along with the PIX4Dmatic project files. I will reply once I’m able to go over it.
-Jon
Hi Jon
That’s files , right.
Thank you.
I delete zipfile from GoogleDrive.
Best Regards.
Seiichi Takayama
Hi Seiichi,
Thank you for reporting this, as it is unexpected behavior. In the meanwhile, don’t select the Trusted location and orientation Pipeline when processing with Arbitrary CRS. I can see that all the other pipelines process fine.
It appears this issue lies with the Trusted geolocation and orientation pipeline when processing with Arbitrary CRS.
I report back here with further information as I receive it.
-Jon
Hi, Jon.
It fixed by v1.38.0.
(from release note)
Fixed calibration issue in Arbitrary CRS for Trusted location and orientation or Low texture planar pipelines.
Thank you.
Seiichi Takayama.
