Hello Pix4D community! I am processing drone flights which I performed in coastal areas of Florida. Processing is generally going well, but for the last few flights I have received the following error: “Generation of image embeddings failed.” I see the error in the log, but the quality report, DSM, and ortho all look OK. I have opened each DSM and ortho in ArcGIS and see no obvious issues with their quality. How do I go about fixing this error? If it is not fixable, is it OK to use the DSMs and orthos or are they flawed in some way? I hav
e included the quality report and log for my most recent flight that threw this error. Thank you!
2024-12-11_13-59-48.txt (553.7 KB)
Apologies - it doesn’t look like I am actually able to upload the quality report due to file size restrictions!
According to the log file, I can see the following error:
GPU device selection error: ‘Outdated GPU driver’
This indicates that the GPU driver of your Intel UHD Graphics 770 is not updated. Can you please make sure that your driver is up to date?
Please also note that if the DSM and orthomosaic are working fine in ArcGIS, then there is no issue on using those.
I hope this helps you.
Spachos
