Just updated to the latest “stable” version and still getting the same fail at generating dsm/Otho if I have defined a region of interest. The only work around is to delete the region of interest after the failure and then run dsm/ortho generate. It is getting irritating on big projects.
@chris3 sorry to hear that the issue persists. I’ll ask a support agent to reach out to you in private, so that we can further investigate the problem.
Do you have a specific set of steps that you do that reproduces the issue consistently? (e.g. when do you create the region of interest, in which order do you do the processing, etc…) Thanks for your collaboration
