Under the heading download images, and the picture of the drone, reads
“?Images” have been downloaded and when I select “upload images” and it changes from “uploading in process” to error during the processing request, please try again ". This is the second project I’ve tried to upload with the same effects.
The download failed probably because the images were not found on the SD card. Then if the images were not copied to the device, they cannot be uploaded to the cloud.
Several users reported the issue of images that we not saved on the SD card during the mission. You will find more information here:
(Android) Images are not captured
(iOS) Images are not captured
We believe reformating the SD card using DJI GO (4) will help.
