Good morning, with the application an error occurs when using the Parrot ANAFI drone, when you order to run a flight and mark the option to see the camera live, the screen appears completely black with a tiny dot in the middle of the screen. You can see that in the middle of the point is the live image of the drone but nothing can be evaluated. The images and the flight get them correctly. El Fallo produces products to see the images live.
I sent them a recreation of how it would look on my phone screen. The phone you use is a Xiaomi Mi NOTE 3. Greetings
The behavior you are describing has not been reported to us so far. You should be able to see the camera view during the mission. As a first step, I would suggest you go through all the basic checks and troubleshooting steps as it will solve most of the issues that can be encountered if properly followed.
