Several flights flown grid style over selected items. After initial processing the camera angles way off and a distorted image along with error in the report on camera parameters are off drone in use, Inspire 1 pro. DJI GO app all parameters are normal. Firmware software on all apps and drone up to date. As I operate the Pix4D Capture app in use. I physically look at the images being captured, all is well as the process moves along.
I also calibrated the compass prior to my last flight. Please give me insight current issue. Thank you.
