Hello!
How to edit boundaries of ortomosaic. More like cut everything unimportant off? I tried to add everything unuseful to “Deleted” but that didn’t work like excepted.
Hello!
Have you tried setting the Processing Area? Honestly I don’t use orthomosaics so I am not sure if they respect the processing area or not.
Setting the Processing area will do the trick. Set it and run the step 3 again
and here are the 2 ways to set the processing area: Processing area :-)
