Hello everyone!
I would like to reduce the orthomosaic created with Mapper so that I only have the plot that interests me. How to do? I did not find the method or the tool… Thank you!
Hi, you can use processing area: https://support.pix4d.com/hc/en-us/articles/202560179-How-to-select-draw-the-Processing-Area. However, you would need to process step 3 again if you draw the processing area before step 3.
