Hi I have a client who wants .dwg files from the Pix4D data with levels.
What is the easiest way of me doing this or is it straightforward for him to process?
Hi Dazansell,
All Pix4D outputs and their compatibility with other software are shown here:
Pix4D-outputs-with-other-software-by-output
*.dwg files are AutoCAD project files. You can create a *.dwg with AutoCAD and import as layers the Pix4D outputs, e.g. the contour lines, the orthomosaic, etc. Then you save it as your_drawing.dwg.
Already discussed here:
[DWG-File-Export
](/t/3365)Best,
