I’m encountering an issue in Pix4Dmatic where a large number of valid images are being rejected on import with a “Duplicate image” warning, and I’d like help understanding the cause.
What happens:
When adding 2390 RGB images, only 600 are added and 1790 are rejected. The warning reads “Failed to add 1790 image(s) – Duplicate image.” The rejected files follow a regular alternating pattern (e.g. left_00003, left_00005, left_00007, left_00009…), with every other image being dropped.
Camera model detected: Generic ShareUAV_R2000_SVCA01_3.6_3504x4672
Why this is unexpected:
The same workflow imported correctly before, with both left and right camera images accepted.
The images are not actual duplicates – they are distinct captures, and the folder does not contain duplicated or backup copies.
I have also observed this same yellow warning with my drone images, not only this dataset, which suggests it may not be specific to a single project.
What I’ve checked:
Confirmed the source folder contains no duplicate or repeated files.
Confirmed I am not re-importing a folder that was already loaded.
[Optional: add EXIF check result here – e.g. “Consecutive rejected/accepted images share identical GPS coordinates and timestamps” or “EXIF coordinates differ between the images.”]
My environment:
Pix4Dmatic version: 2.5.2
My questions:
What exact criteria does Pix4Dmatic use to flag an image as a duplicate (filename, EXIF position/timestamp, pixel content)?
Is there a way to override or disable duplicate detection so all images are imported?
Could a recent version update have changed the deduplication behavior?
I can provide sample images, EXIF data, or a screenshot of the warning if helpful. Thank you for your assistance.
please dear support, are you on this topic already? we haven’t recieved any notice. Please be so kind and give us some feedback on this topic! @Rhea_Garratt If you need more information please let us know. Thanks so much!
Just an idea I have, may this come from the 0.5 seconds capuring intervall of the Slamdevice? We made images every half second. If Matic is reading the exif regarding the capturing moment, can this be the error maybe for the message duplicate images?
Strange anyways, beacuse the names of the files are unique…
I think the dataset you shared with me is related to other posts in the community. I need the Share R2000 dataset to investigate the duplicate image issue.
Could you please add this dataset to the folder I sent you?
I’m having a similar issue with in PIX4Dmatic (2.11.0) where images from two separate flights are being incorrectly identified as duplicates when combined into one project.
I have two Phoenix Recon F4 (Reibo camera) image sets with unique timestamp-based filenames:
Each flight imports correctly when tested independently. However, after importing the first flight and then adding the second, PIX4Dmatic reports 421 images from the second dataset as duplicates and skips them.
The files are separate captures with unique filenames. The associated Phoenix exterior-orientation .dat also contains records from both trajectories.
Expected behavior: Both image sets should import into the same project without being identified as duplicates.
Observed behavior: Both datasets work independently, but hundreds of images are rejected as duplicates when the datasets are combined.
Can you confirm what criteria PIX4Dmatic uses to identify duplicate images and whether this is a known issue?
Yes, there is some unique logic that Matic employs during the camera creation process. First, let me quickly dive into Mapper. Mapper used a different process in which it analyzed every pixel in a dataset to determine image uniqueness. This was very effective, but it could take a very long time to import the images.
In an effort to speed up the process, Matic took a different approach. First, it will look at the geolocation data in the images written to the EXIF. It does NOT check the geolocation when it is written to an external CSV file. The logic is that if there are no geotags in the exif AND the date/time original is the same for all images, then it will determine the images as duplicates.
What is happening is that your drone does not write the geolocation to the images AND the clock gets reset every time you do a battery swap. Thus, you are getting images that have the same date/time stamps.
The only real way to solve this will be to manually write a date/time to the images’ EXIF. You can use programs like ExifTools or EXIF2 to do this. These are command-line programs where you can overwrite info on the images. The time does not need to be accurate, it just needs to be different.
With the help of Mike, I traced it back to the scanners EXIF DateTimeOriginal field. Rather than recording the actual collection date/time, each flight appears to restart its internal timestamp around March 1, 2022. In this case, one flight started around 00:07:11 and the next around 00:06:11, which created a lot of overlapping timestamps between the two flights.
By loading ExifTools directly through the command prompt within my image folder, I used a short script to move that second session 24-hours later.
That was enough to stop the overlapping timestamps from triggering Pix4Dmatic’s duplicate-image detection, and your combined imagery imported successfully afterward.
