I have downloaded a few projects. When I try to extract them I get a boatload of errors. Winzip will not even display the file contents. I can only read using explorer to extract. When I try to extract, I get an error cannot read file. Invalid parameters. So I try to drag and drop the folders. Then I get more errors, file name length too long so I have to enable long file names on my computers. Then I get "error 0x80070057 the parameter is incorrect "for a few hundred files that I try to extract. Can someone please share with me a successful method to extract downloaded projects. Thank you very much!
Hi Scott,
We have seen errors with winzip before. Can you try using 7zip to see if the same errors?
-Jon
