hallo, how you doing, I install my pixel4d software today but the third step (DSM) OF my application is not active, so can you assist on that please?
Sawasdee @nakklampiyaporn,
Welcome to the Pix4D Community
From the description provided, it seems that you are using a Discovery version of the software. This is a version with limited functions. For more information: PIX4Ddiscovery / Discovery mode.
Please follow the following directions to get full access to PIX4Dmapper software:
- Open PIX4Dmapper on your desktop.
- If you are automatically logged into PIX4Ddiscovery, please log out following the directions here.
- Log into the software following the directions here.
- On the welcome screen, select your trial license, and select ‘OK’
- This should open PIX4Dmapper using your valid license.
At this point, you should be able to re-run the project with the desired processing options.
If you are still unable to proceed with your processing, please share a screenshot showing the issue. If you do not feel comfortable sharing this kind of information in the community, feel free to open a Support Ticket.
Cheers
