I extended my trial license for 10 days after it expired and I notice that I no longer can run step 3 in processing. Is this the case? My initial trial allowed me to run all three steps but now it seems I can’t.
Thanks, Love the software.
James Portolese
Hi James,
You are logged in using the Discovery mode. That is the reason you are not able to process step 3. First, I would recommend you to log out of the Pix4Dmapper Desktop. Then, when you log in back, you will see a window like the one attached below. Select the Pix4Dmapper trial from the available licenses and click OK.
Thanks so much for the info. Everything is working now. Is Discovery mode available for free to registered users or does that eventually expire?
Discovery mode is free and it doesn’t expire.
