New to the DJI X5, did a stockpile mapping without GCP’s.
When i use the following settings in the Initial Processing:
This is the result i’m getting:
Uncertainty ellipses:
Is this pattern a sign of incorrect focus? It uses a Pix4D camera model of the database and the report says 15.047mm instead of 15.000mm so pretty close?
Calibration method: accurate geolocation and orientation. Is this OK when no RTK is used?
Only when i set the external parameters to “orientation” the resulting orthomosaic is closer to reality, but it feels incorrect to use the initial position as the computed position if I do not use RTK.
Thoughts?
Thanks!
