DJI SDK error The server may be busy or is not reachable
Hi, Developer_XYZ , i have they same issue, would you be si kindly and share with me they apk’s? Thanks in advance. My email is prusaker@gmail.com
It looks like the problem is showing up on newer versions of android. On a smartphone with Android 7, the program works fine, but does not work on another phone with Android 11 :frowning:
Test results from my side. Drone - DJI Mavic 2 Pro. Smartphones - Nexus 6 (with Android 7) and Xiaomi Redmi 10 Pro (Android 11).
Nexus 6 with Android 7:
Pix4capture v4.5.0 (with Ctrl+dji v1.9.6) works fine.
Pix4capture v4.7 (with Ctrl+dji v1.9.7) works fine.
Pix4capture v4.11.0 (with ctrl+dji v1.9.9) - ctrl+Dji doesn’t connectet to drone with message “DJI SDK error”
Thus for old smartphones, it is enough to roll back the Pix4capture version to 4.5.0, 4.6.0 or 4.7.0.
Xiaomi Redmi 10 Pro with android 11:
Pix4capture v4.7 (with Ctrl+dji v1.9.7) and newest releases doesn’t connectet to drone with message “DJI SDK error”
Pix4Capture with releases 4.5.0 - 4.6.0 - just don’t connected to drone without any error messages.
That is, none of the versions of the Pix4capture works on this smartphone (with Android 11) :frowning:
Thus, the problem is most likely in the interaction of the ctrl+dji plugin with new Android versions (Android 11).
Dear Developer_XYZ
I have the same problem i.e. (DJI SDK error. The server may be busy or not reachable ). Would you give the downgrade version of This applications to solve my problem. This my e-mail address rismabambo019@gmail.com, I would so appreciated if you want to help Me.
Thanks in advance…
I need too please send me in robertocoromanrique@gmail.com
Please
Did you solve the problem? If yes please tell me how.
Hi Gale, i´m having the same issue with the SDK error. I have a Lenovo Tab M9 and i have this logs. I hope they are useful
ctrl_dji[1].log (684.1 KB)
pix4dcapture[1].log (248.0 KB)
Pix4Dmapper[1].log (11.6 KB)
