Can you tell me the best angle of the camera for 3D flights mapping and overlap side and front, and altitude?
Also the best settings and height for circular model.
Hi Mark,
For more information about data acquisition, we recommend this article. Also if you need to better understand the settings of Pix4Dcapture, you can refer to this section of our knowledge base.
I would suggest that you make a first experiment with the default settings of the mission, and re-adjust them later if needed.
