Disable contour line elevation labels
I’m enjoying the ability to have elevation labels on contour lines in the newest Matic/Survey version. However, is there a way to disable the elevation labels? With a lot of contour lines, it makes it very hard to see anything underneath the elevation labels.
Hello @charles.rawls
Yes, it’s possible to disable the elevation labels. In order to do that, you simply:
  1. Go to Settings
  2. Find Labels
  3. Deactivate the Contour line labels toggle
I hope this helps.
