I’m noticing an issue when I use multiple monitors. In particular, when one monitor is 4k, and the other is 1080p.
I’m using windows 10 with Nvidia GTX 1650 and intel i9-9980HK.
There is a small fix by setting the (window) scaling of both monitors to 100%. However, this makes everything so hard to read, and it makes it very difficult to use. If the (windows) resolution scaling is set to the recommended settings.
Any solutions to this annoying problem, other than buying a 4k monitor or setting the 4k monitor at 1080p?
