Creating thermal image in Pix4D
I have photos made with DJI with camera model FLIR 13.0 (640*512). If I set the processing template to Thermal Map and hit start it soon generates the following errors:
Error: No calibrated cameras and
Error e0046: Processing failed. No calibrated cameras.
What I’m doing wrong?
Thank you!
Madis
Hi Madis,
First, I would like to recommend you this article on thermal images processing:
https://support.pix4d.com/hc/en-us/articles/360000173463
Then, Camera Calibration issues can results from a number of factors. Typically an uncalibrated camera results from insufficient number of keypoints matching with neighboring image keypoints to become tie points.
https://support.pix4d.com/hc/en-us/articles/115005481843
No cameras could be calibrated. Possible causes:
  • The image quality is not sufficient (blurry images, no texture, etc.). For more information: 203756115.
  • There is no overlap between the images. For more information: 203756125.
  • The camera model associated to the cameras is not correct. For more information: 203032259.
  • The image geolocation or coordinate system is not correct. For more information: 203755985.
  • The GCP geolocation or coordinate system is not correct. For more information: 203032299.
If you error occurs at the beginning of the process, the cause might be that your camera model is not correctly associated.
At this point I cannot help you any further. If this error persists please feel free to provide us your quality report and log file.
