Hi All,
I’m using Pix4D Mapper for survey applications. My initial survey surface was taken by using GNSS receiver and its a CSV point file. Currently I’m having existing ground point cloud from Pix4D Mapper processing. Is there any way to add my GNSS point file into Pix4D to calculate volume between initial surface and point cloud surface?
@ikk.epoch thank you for asking and for the moment, it is not possible to calculate a volume between two surfaces, but I noted your request. Can you tell me more about your type of project? What’s the use case, what type of project area, what is the end result/report? Thanks!
My initial surface was taken from GNSS spot elevations and its wasn’t a flat surface. After that there is a sand stockpile and I have its point cloud. But if I take base surface as flat surface to calculate sand volume, the calculated volume will be wrong. That my issue.
