Hi, I need to use GPS points to create a surface and calculate stockpiles volume. How can i do it in Pix4d? Thanks
There is a detailed description of the workflow to measure volumes in Pix4D here.
It is also possible to import a SHP file including existing points (GPS positions for example) which will be used as base surface for the computation. Please read this article for more information. You would need to create the SHP file in beforehand.
Regards.
