Converted Trial to Subscription But Still Showing Trial - Limit on Floating License - HELP!
I recently downloaded the Trial of PIX4Dreact to test out and decided to give the Monthly Subscription a try. Subscription is in place, but the license is still showing as TRIAL, so I am unable to use the software on a different machine using the floating license. Any suggestions? Thanks!
Please log out and log in again. If you activated the subscription under the same account, you should see the new license on the license menu after signing in. I see you only have a trial under your account.
Are you sure you activated the sub. under this account?
Best
