Configure vertex display
It would be greet if you can set a parameter to always display the line vertex.
If I select a line, I see circle in vertex, but if I have no selection, the vertex are hard to see.
If you can make a display preference to always display circle on vertex it would be great.
When I draw the edges of road I can put the vertices face to face on both sides.
Hi @vprelat,
Thank you for your feedback and for your use case.
Yes, currently the vertices are not displayed when the polyline is not selected.
I have forwarded your request to the product team.
Meanwhile, a suggestion for vectorizing the edges of a road.
You can use the Create an offset polyline that will copy your polyline.
You can find more information and a short video here:
I hope this helps you.
Have a great day,
Daniele
